Hello Devteam,
I am facing an error on my WordPress website when I install the newspaper theme on my website it will break the basic WordPress features like the media library not load any images. but images show on the front page. also when I try to add a new post on my website it will not allow me to add the feature image for the post.
When I deactivate the newspaper theme it will fix all the issues. can you please help me.
Please make sure the folder files permissions are set as in this guide: https://www.wpbeginner.com/beginners-guide/how-to-fix-file-and-folder-permissions-error-in-wordpress/ and all theme requirements are set as in our guide from here -> https://forum.tagdiv.com/requirements-for-newspaper/
Let me know the results!
Hello Anamaria,
Folder files permissions are set as wpbeginner guide, all the theme requirements are set as your theme guide but nothing changed. The error is still there and I am not able to see the media library. Kindly refer to another solution for our issue.
thanks
Please check if you use the last version WordPress 5.6 with a last theme version Newspaper 10.3.9.1 and check to see if the problem persists.
If after that problem persists, please contact us via email at contact@tagdiv.com and provide admin, cPanel URL and credentials, also a link to this topic in order to identify you.
