This sounds like a caching issue.You can check if is a plugin conflict by checking only with the theme plugins enabled. But since you say when you are logged was working correctly, then it can also be a cache or object cache https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/.
Please let me know what plugin for the cache you have and the server.
You can use Smush, WP Super Cache.
WP Super Cache is tested with our theme, Smush is not tested, but some users use it without problems.
Also, please check those topics about pagespeed https://forum.tagdiv.com/topic/newspaper-theme-has-caused-my-website-to-slow-down-considerably/
