Menu links does not work when Mobile Site Plugin is enabled
Good day.
How come Mobile menu links are showing blank pages is this an error? This prevent us to use Mobie site plugin which is actually much faster and smoother than regular mobile site… Site moves annoying without Mobile site plugin.
Hello chadsrl,
Unfortunately, our theme has not been designed to use this plugin in our theme, sorry! We have no idea about the theme behavior with this type of plugin and also, we cannot say for sure if it will work or not with the theme, sorry! Also, we cannot provide support for untested plugins, sorry!
Hey Catalin; forgive me but I am little confused… What do you mean with “untested” ?
I am talking about the official tagDiv plugin https://forum.tagdiv.com/the-mobile-theme/
Hello chadsrl,
Please provide your website URL so I can take a closer look at it. Also, please provide screenshots with the issues so I can localize it.
http://www.adelturk.com
screenshot 1 | Screenshot 2 | Screenshot 3 |
In case you need to access to WP-Admin panel you can use http://www.adelturk.com/n0hack user:tagdiv pass: meetmeinrome**
Hello chadsrl,
I have inspected your website for mobile devices and I saw that your menu items seem to work. Also, I notice that you are using the mobile theme and that’s why some pages are not displayed because you are using the Visual Composer for these and the mobile theme does not recognize it, sorry!
For more information about our mobile theme plugin, please check the following topic here -> https://forum.tagdiv.com/the-mobile-theme/
Hello Catalin;
Thank you for the inspect.
What link exactly did work your inspect because non of us not seeing any link working. Made you a screen record here https://www.youtube.com/watch?v=84e_1rAk7aQ&feature=youtu.be
About the Visual Composer. That comes with the theme plugins. We never needed it actually. Will problem be sloved if I disable visual compuser?
Would you please come up with a solution. https://forum.tagdiv.com/the-mobile-theme/ just a show case not giving much solution with our issue.
Please tell us what to do to make Mobile theme works fine with links when mobile displays.
Thank you
It seems there is a bit of misunderstanding here. When you use the mobile theme plugin, content for mobile pages has to be entered in the Mobile editor for each page, just as the guide specifies
– https://www.screencast.com/t/s4CAC0te
Content in pages built with the composers will not be displayed. This is meant to improve the performance on mobile, keep things as simple as possible.
Please note that the mobile theme plugin is optional, you can simply deactivate it. Then the same pages and content from desktop will be displayed on mobile. The main theme is fully responsive and will adapt to every device.
Good day Simion.
Thanks for correcting the missunderstanding. I guess mobile theme is not a proper option to use with Newspaper theme for the moment. It would be wonderfull to have it as almost everyones now visitors are mostly using (%70) mobile devices. Desktop version of the city is actually less important than the mobile version. Anyway…
I am not sure if that is connected but since you accessed to site with the credentials I gave here My “tagDIV Composer” not working no more. An endless loading circle comes up when you hit “Edit with TD composer” on top bar. I reinstall the plugin, did not help either. Also Unique Articles is not working either. When I hit “Unique Articles” on a page settings it’s takes me to same place and no where else like I never clicked…
That did started like yesterday or early this morning. Would you please check if you did any change when you accessed to check with Mobile Theme menu issue…
I created a new user cause I am not sure if here is safe to share these information.
Would you please take a look and tell me what to do.
user: support
pass: **needhelp**
thanks
The main theme is fully capable of displaying the website on mobile devices, the mobile theme plugin is optional.
If the composer is not working properly, first please check the theme system status and make modifications to the parameters mentioned in this guide, if necessary
You could ask your hosting provider to make them for you, if needed. Then make tests again, there should be no more issues. If the problem is still present, a next step would be to deactivate all plugins except theme plugins and clear all caching.
If there is still a problem after, please send us an email at contact@tagdiv.com and provide admin login information, so we can take a look.
Also paste a link to this topic in your email.
The unique articles option will ensure that the content loaded on initial page load will be unique, meaning no duplicates. This is affected by pagination however, if this is used
– https://forum.tagdiv.com/unique-articles/
