Hello
I have a problem I have been trying to work out for ever 1 week
In my site you will see I have a blue menu bar. This is works fine. No issue. But please take note of my menu and you will see some have drop down items marked with the down arrow.
Now with these items in the menu bar with the down arrows. If I turn on cloudflare automatic platform optimisation or try to cache cc and js you can no longer click on these. The drop down wont work. BUT. This is the very strange part. They will work on ALL other pages of the site. Just wont work on the front page only
What is this?
This is strange
When I stage my site using a something different that is not www such as
staging.mysite.com I dont have the issue
I have some kind of www rewrite issue in my code or my database. Its not in my DNS, cloudflare or DNS settings
Hello
Of course you see it working. I don’t have cloudflare automatic optimisation turned on right now.
But. If I turn it on. All the down arrows in the menu turn into squares and not clickable
If you want to use Cloudflare, please make sure it is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/, you need to disable the Rocket Loader.
