Hi. I will edit numbers of show subcategories on global menu
https://imgur.com/a/9SdgCQ9
AND NOW, MY MENU It shifted.. / moved… why ???? Look:
https://imgur.com/a/586MGOm
MENU is not on good space….
hot to repare this?
I can’t manage in any way. How to restore MENU to the good place (via demo)?
and sub menu after scroll site not run….. help me please 🙁
looool…. after update theme (for load INSTAGRAM photos), mobile version its bad….
looks completely different from the home page. Before the upgrade it was good. What should I do now ….
Please notice that we take in order of time the topics ( time when was post the question ) to answer the question, and if you post/replay again in your topic the time will change and will be move to recent question, therefore the answer will be delay.
These option from mega menu will apply in this way -> https://i.imgur.com/i2BXiTa.png also you can make change for the mega menu without subcategories -> https://i.imgur.com/Jc5XpeG.png -> https://i.imgur.com/VOkghxh.jpg
The menu can be moved only if you drag it, this is the only what it can be moved.You can click on it and drag in the area where was before.
Newspaper Theme: How to Upload a Logo and Turn the Sticky Header On/Off -> https://www.youtube.com/watch?v=HXQQygkCCJo
In the most cases the mobile version is different if you are using tagDiv mobile theme plugin if you want to have the same layout, you can deactivate the mobile theme plugin or use it only for amp option.
Let me know the results!
The menu can be moved only if you drag it, this is the only what it can be moved.You can click on it and drag in the area where was before. – not run…
Make sure that the menu is set to be inline like this -> https://i.imgur.com/aSTFY4h.png
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login. We will take a look. Include a link to this topic in the email.
