Menu not showing site name
Thank you so much!
Hello! When I opening https://pipsik.club/category/biografii_znamenitostei on my site, its showing https://www.screencast.com/t/5Y6i7b77Hl
The rest categories is looking Ok.
What is it and how to fix that?
Please make a full backup to all files and database, and try to revert to version 10.3.9.1, and after trying to reinstall the theme and plugins to version 10.4. and make sure the update is correct, using only the plugins are activated.
Hello! Can you tell me please how to change comments color made by admin? To clear the difference between guest comments and admin comments
I made a custom code CSS and look like this => https://www.screencast.com/t/9aeAt6TvtYHm
The code is
children {
background-color:#eef5fa;
Set the code in Theme Panel ->Custom code -> Custom CSS
Hope that helps you!
Not working with custom CSS, only if change in Style CSS. And how to change admin name comment color?
Please send screenshots and a link to a post when you have comments.
Also, to change the color comments made by the admin you can use this code => https://i.imgur.com/WtaH7Di.png
.children .comment-content{
color:red;
No, I want red color name of Admin, not messages. Like you name Anamaria is blue.
https://pipsik.club/interesnye-fakty/interesnye-fakty-o-salate-olive.html
After post there is 2 comments. The last is mine, and I want my name “Van Moonlight” to be appears in red color please.
I’m sorry for the misunderstanding, you can use this custom code https://www.screencast.com/t/ygadPN70WIB
.children cite{
color:red;
Works perfect! Thank you
Viewing 10 posts - 76 through 85 (of 85 total)
