Hello! I like this theme, but have some trouble with main menu. Its not showing site name
This topic was modified 5 years by
mikevanmoonlight.
I am not sure I fully understand what you mean with the website not show the name. Do you mean that you have added a logo and that it is not displayed or what exactly do you mean?
If you referring to his please check this guide about how add a logo => https://forum.tagdiv.com/logo-favicon/
Actually no. I uploaded logo and thats ok. It’s not showing text logo or text logo tagline. But this only half of problem. The top menu overlaying top part of my site. I tried all header styles and no one helps. I want menu do not overlay top site and show site name like “PipsikClub” after logo or instead of logo.
Above question I mean on desktop version. Also the animation of opening menu on smartphone is slow, how I can force it be faster?
Please edit the page, and select the page attributes on default => https://www.screencast.com/t/GdYjOa6EVGdD and see if the problem persists, also, for the mobile menu there is no option to make it open any longer.
That was helpful, thank you! For mobile menu I want it to open faster.
Also, a new problem is detected. I see no thumbnails here and do not really understand what i should do https://pipsik.club/category/interesnye-fakty
Also, how to delete empty columns close to footer? https://pipsik.club/
TagDiv composer cannot delete them
You need to enable the thumbnails for those blocks from Theme Panel -> Block Settings -> Thumbs on modules/blocks => https://www.screencast.com/t/bOpWqaggST
If you want to delete an empty column you need to know that empty columns are part of the row, and you can’t delete the column only the row that holds the column, this can be done with: using the right click on the row icon -> http://prntscr.com/owlyuw -> http://prntscr.com/owlynq or using the drag and drop -> http://prntscr.com/owlz2r or you can simply click on the row and press the delete button from your keyboard.
Hope this helps you!
That was helpful, thank you very much! Also please tell me how I can edit footer, because TagDiv not allowing to do so.
The footer templates from Cloud Library do not have the button to be edited with tagDiv Composer in the backend. Please check this guide:https://forum.tagdiv.com/footer-templates/
The footer template can be edited only from the frontend if it is assigned, edit a page/post template with tagDiv Composer and go down to the footer. => https://www.screencast.com/t/rpfNhfyrF
Thanks again! Fixed that issues, but have one more. The Flex12 layout showing different height of thumbnails. https://pipsik.club/
How can I make them be the same height?
Also i made new footer for homepage but I see old footer on category pages? https://pipsik.club/category/interesnye-fakty
Post text I would like to make more wide. https://pipsik.club/interesnye-fakty/goroda-i-strany/interesnye-fakty-o-kemete-drevnem-egipte.html
How can I do that?
If you referring to this block => https://www.screencast.com/t/xh40lu3nhNm, then this can be done only if you set an excerpt/length of words or letters for posts title and content https://i.imgur.com/a53B2U5.png -> https://i.imgur.com/4LWvCNt.png or using a custom code CSS.
For the footer on the category page, please edit the page, and in Manager (Website Manager) you need to import the footer that you have on the homepage or you can set the footer in Theme Panel -> Footer and select the footer, this will be applied on all pages/posts => https://www.screencast.com/t/PBkNOswg3k3w
Also, for the content on the post, if you don’t have a sidebar then you can set the layout on the row to 1/1 => https://www.screencast.com/t/TL6utlhfQW
Thank you very much!
I just set up prebuilt website https://demo.tagdiv.com/newspaper_magazine_pro/
but my site is looking smaller https://pipsik.club/
How I can make my site wider to be appears exactly as a prebuilt version?
And one more question. I would like to set up a bigger font on post page, but (THEME PANEL-POST CONTENT-18px) doesnt make any effect. I see same size of font. Also I would like increase text size on smartphones
I don’t see a difference between your website and the demo. If you saw it, please provide some screenshots.
Also, this is a video about fonts => https://www.youtube.com/watch?v=jQvA64uTLkI
If you have a single post template, select the Single Post Content and in the tab “Style” you can adjust the fonts => https://www.screencast.com/t/jzuv6NVB
Thank you for helping me with fonts!
Now about main page width layout. It’s a strange why you don’t see a difference.
Ok I made screenshots, please see attached. I want to clear, I am not upscaled nothing, this is real sizes.
My site
Prebuilt Sample
Do you see the edges distance?
This reply was modified 5 years by
mikevanmoonlight.
mikevanmoonlight.
Also found what post settings (such as: SHOW AUTHOR NAME | SHOW DATE, SHARING, NEXT-PREVIOUS ARTICLE) not taking any effect when I trying to edit it from Theme Panel. So I have to remove everything manually using TagDiv Composer. And I wonder why?
3. I increased font on desktop version but not on mobile page. Can you please refer me where to look at? I need to increase text size on mobile post template. Thanks
1. For me, looks fine => https://www.screencast.com/t/jIgjzVXO5 you need to zoom out to see like the demo your website.
2. For ‘SHOW AUTHOR NAME | SHOW DATE, SHARING, NEXT-PREVIOUS ARTICLE) ‘I don’t understand which settings didn’t work, normally if these are added with the tagDiv composer then these need to be edited with tagDiv Composer, the changes from the Theme Panel apply to the standard template, not to the single post template from the Cloud Library.
3. You need to select the mobile page =>https://www.screencast.com/t/3ySrS6ab , edit with tagDiv Composer, you can set the fonts => https://www.screencast.com/t/ZeXOZxEyOega
1. Ok, is there any chance I can make the Home page layout to be a little wider?
2. How to setup mobile version on fullscreen?
3. On category page https://pipsik.club/category/biografii_znamenitostei
when I pressing 2nd and 3rd button (next page) it is loading the same content. How to fix that issue?
1. If I understood it correctly you want to make the layout full width, then to change the website width, you need to make sure that you don’t have set a background color/image in the Theme Panel because this makes your website boxed. Make sure this option is disabled => https://www.screencast.com/t/ejiNPCBF
To set a page to full width, you’ll need to edit it with tagDiv Composer like this -> https://i.imgur.com/i5IUJ9E.jpg add or select a row and stretch it after your needs -> https://i.imgur.com/WKYebPX.jpg -> https://i.imgur.com/TO1BZ3M.png -> https://i.imgur.com/Yq8UCv3.jpg
2. I am not sure I fully understand what you are looking to edit, and what you mean with the fullscreen.
Maybe you referring to remove the white space from here => https://www.screencast.com/t/ZaYJdjW3, if yes, then you need to set the margin left and right on the row to -20 => https://www.screencast.com/t/AplrIm3zs5
You can use this method for both (mobile responsive version or mobile page)
3. For the category page, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
1. No, I would like to keep boxed layout but little bit stretch that box like we did css on mobile layout in #2
2. That tip works perfect, thank you!
3. I have no child theme but using nesessary plugins like akismet and classic editor. Is there any another way to fix that issue but not deleting all plugins? I am thinking about deny pagination or setup an infinite scroll
4. How to add a tags to my articles?
5. I don’t like a blocquote style. How can I change it?
mikevanmoonlight.
