I do not speak English, Google translates my sentences.
In the Newspaper menu:
https://xxxxxx.fr/wp-admin/admin.php?page=td_theme_panel
the link does not change and it does not matter which heading is chosen:
footer, ads, categories or others
the only one that changes is import / export
Everything worked well but now
I can not do anything ?
Thank you for your reply…
Bonjour,
Je ne parle pas anglais, Google traduit mes phrases.
Dans le menu de Newspaper :
le lien ne change pas et peu importe la rubrique choisie :
footer, ads, categories ou autres
le seul qui change est import/export
Tout fonctionnait bien mais maintenant
je ne peux rien faire ?
merci de votre réponse…
So the theme panel is not functioning correctly? What exactly is happening? Do you get the continuous loading animation and theme panel is not responding or opening the sections you are accessing?
If that is the case, the first thing to do would be to follow this guide
Insufficient resources can cause problems like that. Increase them as mentioned, or contact the hosting provider and ask them to make the necessary modifications if required.
Or it could be caused by a security module or plugin. If you use Wordfence set it on learning more
– https://www.wordfence.com/help/firewall/options/
Similar topic here – https://forum.tagdiv.com/topic/cant-save-theme-options-2/
Let us know if there is still a problem or I misunderstood something.
