hai ..thank for replay ASAp for https://forum.tagdiv.com/topic/menu-problem-3/#post-84719. .. I have already identified the problem. But the menu stil have some problem … I’ve used this theme at both the website. One is version 6.5.1 and other is versioan 6.6. The problem is with 6.6 version.. when i install Press Permit Core plugin the menu become problem .. it is different with 6.5.1 that i dont have any problem…why Press Permit Core plugin is incompatible with new version…
Version 6.5.1 – http://umno-selangor.com/
Version 6.6 – http://umnosubang.com.my/
This could be the case as the code gets changed from version to version that some plugins might work on a particular version and not work on another one. Unfortunately the plugin you are using is not tested with our theme and we cannot guarantee that it will work 100%. You can try to see if the problem is still there without other plugins as well. Disable all of them except Press Permit Core to rule out other conflicts.
