Mixing Smart Lists in Posts
Hi TagDiv,
Is it possible to Mix SmartLists into Posts. Example Can We Mix This Smart List inside This Post.
Cheers
AM
Hello amitmadhra,
Using [td_smart_list_end] shortcode, all the content after it should appear on each page. So use it at the end of your smart list if you want that content to appear on each page – http://screencast.com/t/iwqHG8yM – http://screencast.com/t/7lzXd25fk – http://screencast.com/t/xHu2hRXXk
Please provide a link if you still have issues with smart list so we can check and make sure you use this guide to create it – https://forum.tagdiv.com/smart-lists/
