Mobil theme problems
I’m using the theme bu i don’t really understand how to use the theme mobile.
I create the mobile home page , but impossible to see this page when i try to see my site on a mobile..
What are the different steps?
What are options to activate are not?
This is very very confuse…
According to our guide from here https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/ now you can create mobile pages and mobile templates using tagDiv Composer. To assign that page for mobile you need to select it from the mobile list -> https://i.imgur.com/7ZvoGr6.png when this is selected will look like this (in list will be with green)-> https://i.imgur.com/eJtnJEo.png for cloud templates you need to do the same steps, but the assignations is just a little different -> https://i.imgur.com/HKKg73y.png
If there is no template assigned then it will be use the responsive version of the cloud template that is use on desktop.
Also make sure that the mobile theme plugin is not enable -> https://forum.tagdiv.com/the-mobile-theme/ or if you are using it, make sure that is only for amp -> https://i.imgur.com/foGx8BX.png otherwise will overwrite the mobile page.
Hope this will help you!
Calin – to be clear then if you use the mobile theme BUT on AMP only – you can still use the new mobile theme design templates ?
Hi PatWire,
Yes, if you are using the mobile theme only for amp -> https://i.imgur.com/iyVw5ME.png -> https://i.imgur.com/e2XZ53m.png then you’ll have the new version of mobile and mobile theme plugin layout on amp.
