Mobile AMP Problem
I want to ask, why when other people visit my site they will see my site as a mobile amp version but when I am or other admins view the site as a normal view?
Can you help me to rectify the problem so all the visitors can view my site as a normal view?
thanks in advance
Hi AhmadiKatu,
Usually, this situation appear when you are using the mobile theme plugin and the cache plugin that you are using do not have mobile cache support (or is not enabled).
We recommend to use the WP Super Cache with those settings https://forum.tagdiv.com/cache-plugin-install-and-configure/ -> https://i.imgur.com/pPzH3D4.png
I hope this will help you!
