I have checked your site and did not found any issues with menu item on Chrome – http://screencast.com/t/GGs3BeCx7N
1. Do you use any shortcodes related to those plugins in that page?
Also please provide more details about this. How do you add a page in the menu?
As above you say:
As soon as I “UNCONNECTED” the Page ID from the Menu, all the plugins worked fine.
And in the last post:
Why adding pages to the menu (to allow a full dropdown that is NOT a mega menu)
2. Please try this custom css to hide posts and comments count – http://screencast.com/t/OuvOqy6hhu
.author-box-wrap .td-author-counters {
display: none;
Okay, if you’re saying the menu is hovering on Google Chrome, then I’m okay. It just has forced me to CLICK to make the dropdown come down on Chrome.
1. I create a page, then add the page ID # into the menu section. (enter the page ID). Yes, I did it exactly the way it was described above. I do have some shortcodes, but no shortcodes pertaining to Ultimate Social Deux, Theia Post Slider and Awesome Navigator (the three that get screwed up).
2. Thank you, it worked.
I add a page number to the menu, like this: http://www.screencast.com/t/peXY90pQd
Then it results in a dropdown that becomes messed up (with Ultimate Social Deux and Awesome Navigator, like this: http://www.screencast.com/t/peXY90pQd
Also, it doesn’t allow Theia Post slider to actually slide to next page: http://www.screencast.com/t/nNtTynjcF27
The menu works FINE on non-post pages, but completely clashes with post pages due to those three plugins: Ultimate Social Deux, Theia Post Slider and Awesome Navigator.
If I cannot get this solved, I’ll need to get those directions back on how to implement UberMenu. It looks like you guys deleted the earlier messages. The issue I’m referring to is the one where when UberMenu is implemented, it creates 2 mobile menus instead of the normal one. ***1 Flyout, and 1 on the Main page under menu bar….ONLY on mobile, under responsive break point.
Thanks,
***SEE LOOK….those 3 plugins are FORCING Themselves into the Page Dropdown. http://www.screencast.com/t/DE3eWbbGD
Additionally, the comments button is NOT auto scrolling down to my comments on the mobile version.
Is IS working on desktop, but not mobile. For Newspaper theme I would implement the #respond and #comments code to the Disqus plugin to make it work, but now it seems like those don’t matter.
What can I do to make sure the comments logo, or count, allows the reader to auto go to my comments once clicked on?
Thanks,
Unfortunately we haven’t tested the the with those plugins so we aren’t aware of their coding therefore we can’t provide any exact answer on this or what could be the issue here but if you could provide your wp-admin login details we would gladly take a look at this and see if we can find the reason of why the theme’s page mega menu ins’t working with those plugins and if we can find a solution for this.
We haven’t deleted any messages but due to the large numbers of comments this tread has the is has become paginated so I guess you refer to the replies from the first page: http://screencast.com/t/ocR3JQyMhxu
Turn on the ubermenu so we can look into this also and give us wp-access.
Related to the comments link issue on mobiles please note that we are aware of it and we have it on our attention and it will be fixed as soon as possible.
Please write us an email and send your admin login details at contact@tagdiv.com and also include a link to this tread so we can know who you are or provide your issue’s details.
