Hi, I had 2 questions regarding the mobile theme .
1. I wanted to change the background of my mobile menu. When I uploaded a image : https://www.screencast.com/t/tTRfOFCpjPNK
it doesn’t seem to appear on the mobile theme :https://www.screencast.com/t/tkJhfa3Uk
How do I fix this problem?
2. I installed the wordpress ‘WP forms’ and ‘give donation’ plugins. The plugins both say that they are mobile responsive. But they don’t seem to work on the mobile theme. This seems weird because an other user from tagdiv uses the same plugins and they both seem to work on his mobile website (www.sociedelic.com)
Is there someway I can make these plugins work on mobile?
*Update, I realised that any page that I make won’t open in the mobile menu. when I open a page I will only see the title of the page : https://www.screencast.com/t/Ob3RHeHFVwEB
please help me with a solution.
Check this guide on mobile theme https://forum.tagdiv.com/the-mobile-theme/. Plus, you won’t see the background for mobile if you use the mobile plugin.
Thanks for your reply.
When I dissable the plugin. the pages that I made work. The only problem now is that my mobile homepage is a mess. I made costum blocks for the homepage for the desktop. But they don’t fit well with the mobile design.
I can’t find an option to just get the normal mobile design.
That would be the normal mobile design. Elements on pages are created to be responsive, they will adapt for the device width. With the tagDiv composer you can now hide elements by device, rows, columns and most elements have the option. A related topic here
– https://forum.tagdiv.com/topic/change-moduleblock-12/
If you use the mobile theme, page builder content will not be displayed. You must then create 2 versions of a page, one for desktop how you wish and one for mobile using the sole capabilities of the mobile editor as mentioned in the guide.
