Mobile menu not appearing and only top one block posts appearing
Sir,
The following problems appearing in c/w tagDiv Mobile theme activation/deactivation
1) If I activate tagDiv Mobile theme Mobile Menu appearing but only one block posts appearing in mobile page
2) If I deactivate tagDiv Mobile theme Mobile Menu disappearing and all block post(entire home page posts) appearing
Now I want that the tagDiv Mobile theme should be activated and Mobile menu should appear in mobile page and all home page posts should appear.
Kindly look into this and intimate the the resolution( Screen shot enclosed)
Mobile menu appearing after activating tagDiv Mobile Menu
Only only block posts appering after activating tagDive Mobile themeMobile menu disappeared after deactivating tagDiv Mobile themeAll block posts appearing after deactivating the tagdiv mobile theme
Hello !
You are using mobile theme plugin. You will have to create a menu for your mobile theme. Please note that this is an wordpress option: https://www.wpbeginner.com/beginners-guide/how-to-add-navigation-menu-in-wordpress-beginners-guide/
Sir Now Menu appearing in Mobile theme after chose Mobile + Amp option in in theme penal(Mobile setting). But now only latest article appearing in mobile home page. All home page blocks/posts not appearing. If i choose only AMP option instead of Mobile + AMP all posts appearing. Please confirm how to do setting to show all home page posts in mobile with Mobile + AMP option.
Website link is : https://dopinida.com
Hello !
The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme. The mobile editor will not render shortcodes !
