Mobile menu/search settings from theme panel do not encounter properly.
Brain Balance Mathematics
    Hello @Nareshpatkare!
    Here you can remove/set a picture for mobile menu background: https://www.screencast.com/t/x3Xrln2b88x
    And the background color here: https://www.screencast.com/t/PbU3hQpDqHh
    The opacity of the mobile modal can be changed from Theme panel -> Background -> Mobile menu/search background: https://www.screencast.com/t/hcRoHastuO -> https://www.screencast.com/t/SQapAaaiLRwY
    Please provide more information about your issue, so I can help you efficiently.
    Dear Bettina,
    I already know the setting options that you explained from where it will be changed. My problem is that the changes are not incorporated even after making the relevant change. Truly bad experience after spending so much money.
    Help me ASAP.
    Thank you
    Hello @nareshpatkare!
    Please check this topic: https://forum.tagdiv.com/topic/theme-panel-settings-are-not-saving-2/ and let me know the results.
