Please check the console when you try to save the changes made in Theme Panel maybe is possible to be from the firewall or security module which blocks the admin-ajax.php request, which usually displays a 403 or 404 error.
If you don’t use a security plugin, please ask your host about this, maybe you have a security module that blocks this.
If you use a plugin like Wordfence please set it in learning mode.
Also, if you are using Cloudflare, please make sure that is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/, you need to disable the Rocket Loader.
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv ones, also if you are using a child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
I disabled all plugins except those critical, still the same issue. The only known change I made was updating to 11.4.3
Hello @peternichol!
Please provide more information about your issues, screenshots (with what you’re trying to save in the theme panel) or a video and your website link, so I can help you efficiently.
The sorting tab is still not disappearing from categories and tags pages from right corner – https://gaadiwaadi.com/bikes-news/
