Mobile problem
I need help for the mobile version.
On the desktop in Appearance with Live Preview I see the mobile version I worked on, and on the mobile a simplified version (only with the latest articles, without advertising, without pinterest, without instgram, without subfooter). Can you help me with this problem?
Hello !
The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme.
Thanks Vlad!
