hi there, i run my site online today and have some mobile problems.
1. the mobile theme dont work. when i enable plugin in mobile device in linke its says the theme not work ****.
2. the search dont work in mobile.
3. the menu dont show full screnn in mobile pop up appear!.
can you please check it?
thanks a lot.
p.s i have display:none in search now so dont have problems.
Hello vachos,
First of all, please ensure that you have fully updated your theme to the latest version of it (Newspaper 7.1.1) and also, all the required plugins to the latest version of them (Visual Composer 4.11.2 and Social Counter 4.1). Then, if you want to display the mobile theme, you will have to install the mobile plugin from the premium plugins list, from here -> http://screencast.com/t/1c8WDcsSd To avoid any conflict, please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches, purge CDN file is you are using the CDN system and install only the plugins that come bundled with our theme and rule out the conflicting plugins. Please note that our theme (mobile theme) is fully tested and still working as properly. For more information about mobile theme, please check our documentation here -> https://forum.tagdiv.com/the-mobile-theme/
Thaks for your understanding!
