Mobile Template is not working, (I know, problem is me)
Ok so I have installed and built enough of the site to get it working on mobile but for some reason its not working. Need Help ;-/
http://www.TravelStyleNews.com
Hello ravester,
I have checked your website and I did not saw any problem with your mobile theme. It seems that the mobile theme is working fine on your website, right? -> http://screencast.com/t/3Pmwig75j I have checked your source page and I noticed that you are suing W3 Total Cache as caching plugin. Please notice that this type of plugin is not tested with our theme and it could be possible as this plugin to create some unknown issues in theme. If your problem will recur, please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with the theme and rule out any conflicting plugins.
When Im go into the mobile the Destination lifestyle Photography menus open but no content apart from the template.
Cheers
hello,
The mobile menu will not show the mega-menu option. That is an option only available for desktop. You use the mobile theme plugin so you will be able to create a whole new menu without mega-menus. Add your favorite menu items and then place the menu on the mobile menu spot here: http://screencast.com/t/imXZPBLKU3nR
Hi I cant seem to find any were to control for the mobile, Is there a a tutorial, I need to change the Newspaper 7 logo, and the Adds, Thanks
Once you activate the mobile theme, these settings will appear in the theme panel at the very bottom: http://screencast.com/t/qaFWM0pti If you do not have this pannel, then yopu do not have the mobile theme active
Please read this guide: https://forum.tagdiv.com/the-mobile-theme/
