Mobile Template of newspaper creating a problem
hi sir
i have installed theme at designposts.net
I have installed plugin of mobile theme as well. Sometimes, it displayed mobile version on iphone viewing it, sometime it displayed desktop version of newspaper, attached screenshot as reference of more understanding.
View post on imgur.com
2) How to make adsense unit align left on desktop version > http://prntscr.com/cqvjbn (Screenshot)
Post Articles > http://designposts.net/40-best-free-resume-templates-to-download/
can we disable below title unit or header adsense unit on any particular post? any shortcut
3) How to fix these ? after i tested theme on
https://developers.google.com/speed/pagespeed/insights/?url=designposts.net&tab=desktop
thanks lot
  • This topic was modified 10 years by aliqayyum.
Hello aliqayyum,
1)Please try to clear all your caches, purge CDN files if you are using the CDN system, empty your server cache (if you do not have any access to do it, please request this to your hosting provider) and then test it again and check the results.
2)Try the code below and place it in Theme panel->Custom CSS area.
The code is ->
.td-g-rec-id-content_top{
float: left;
margin-right: 15px;
The result -> http://screencast.com/t/Q4olOZWxYyN
3)Please notice that the speed of your website depends on how well your site is optimized. Please notice that this is not a simple task and if you do not have any experience in this regard you will do not bring good results for the theme. Please notice that we have a speed optimization tutorial but this is addressed only to advanced users. So, if you follow the steps which are presented in this tutorial here -> https://forum.tagdiv.com/how-to-make-the-site-faster/ you can increase the page speed loading and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because the speed optimization services is not covered by our support policy, as you can read here -> https://forum.tagdiv.com/support-policy-2/
Hope this helps!
