Mobile theme problem with W3 Total Cache
I just updated to Newspaper 7 and everything worked fine. I also installed the mobile plugin, a great plugin by the way, however after few hours, i started to see mobile version on desktop using internet explorer and google chrome. also on my mobile, I started to see desktop version of homepage.
After investigation, I arrived to the conclusion that it is a caching issue.
First I paused cloudflare and kept only w3 total cache. the problem was not resolved.
Then I used user agents to passthrough but the problem is still there.
Anyone can help please.
my site is http://www.midronepro.com
I’ve checked your site and now it’s deployed fine on both mobile and desktop: http://screencast.com/t/0gKaChP5mQYH – http://screencast.com/t/4Y8PIHJ4
If you still need assistance on this please provide more detail and we will get back to you in shortest time.
P.S As a cache plugin we recommend W3 Super Cache, here you can check our documentation: https://forum.tagdiv.com/cache-plugin-install-and-configure/
  • This reply was modified 10 years by Andrei L..
Hi Andrei,
Thanks for the support. I think it is working now.
by the way, Using wp super cache plugin I´m getting 65 speed for desktop and 63 for mobile.
with w3 total cache the score is 80 for desktop and 68 for mobile.
I still don´t understand the issue of conflict for the speed booster plugin.
Regards,
Please follow this topic to learn about speedbooster’s compatibility function: https://forum.tagdiv.com/topic/incompatible-plugin-detected/
