Mobile theme and AMP Problem
I have installed mobile theme and AMP plugin. but I open website on Mobile, that time my pages data showing blank like home,disclaimer and contact us.also Official AMP for WP is showing green color active but its showing activate in normal installed plugin option.please help
Mobile theme pages content not showing like home, contact us form
Hello !
The pages don’t render because you are using The Mobile theme, was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme. The mobile editor will not render shortcodes !
Thanks my mobile theme working. but AMP is not working.Missing or invalid structured data item found error when testing AMP pages.kindly find below links.
https://www.screencast.com/t/NgWIgzRMQ
https://www.screencast.com/t/qm07pibg
Hello !
