Mobile theme does not work
I activated mobile theme plugin, but I see a mobile version of the mobile theme once and the correct version from the plugin. Sometimes the mobile version of the theme is on the home page and the version generated by the plugin is already generated on the subpage. What’s wrong?
Usually, the problem is from a cache plugin, we recommend using WP Super Cache plugin with the settings from our guide -> https://forum.tagdiv.com/cache-plugin-install-and-configure/
Sometimes I see the mobile Theme plugin version on desktop, Is it just about WP super cache?
As I said, the problem is from the cache plugin used, because the mobile layout will have a different design and most of the cache plugins do not recognize this and provide the mobile version for desktop (or vice versa).
Also, if you use multiple cache plugins this problem may occur.
We tested the WP Super Cache plugin and this problem did not appear, that’s why we recommend it.
I have placed the WP Super cahce plug in accordance with the recommendations and the problem still exists 🙁
Please send the link to your website to investigate the problem.
I just checked your website and seems you have also a LiteSpeed cache plugin => https://www.screencast.com/t/IdH6xCfqCBef, usually this plugin doesn’t recognize what version it should display mobile theme or mobile page version.
