Hi, I would love some help with the mobile theme.
1. Currently, I have selected “Mobile + AMP” in my theme panel. But, I am actually not clear about the differences between “Mobile + AMP” vs “AMP”, could you briefly explain?
2. What is the right way to check if my website is AMP ready?
3. Also, I am unable to locate any mobile editor or where I can make some changes to my mobile theme. For example, I would like to add my website title on the mobile menu, remove the article view count, comment count and author image in the mobile article page.
I am currently updated to newspaper 9.7.
Your help is much appreciated. Thanks!
Using mobile+amp you’ll have the same layout for mobile posts/pages and amp, but you’ll need to make a new content in mobile editor for pages and amp.
Using Amp you’ll have the same layout on mobile like on desktop, but the speed will be lower, and you’ll still need to make content for pages in mobile editor, if you want to have amp on pages.
Please check our documentation for mobile theme -> https://tagdiv.com/mobile-theme-get-mobile-ready-with-newsmag-theme/ and How to Make an AMP Ready Website with Newspaper Theme -> https://tagdiv.com/amp-newspaper-theme/
If you are using mobile theme you have for the moment only few option to customize the mobile theme -> https://www.screencast.com/t/Msv4Q7Ka9H
Similar topic: https://forum.tagdiv.com/topic/about-mobile-plugin/
May I know which is the most recommended setting?
“Mobile + AMP” or “AMP” only?
Is there any possible way to add a logo on the mobile theme menu?
such as this -> https://prnt.sc/njdh51
Yes, you can set a logo for mobile, you need to go in Theme panel>Header > Logo for Mobile -> https://www.screencast.com/t/WLhKBBUENy
Logo & Favicon in Newspaper Theme ->https://forum.tagdiv.com/logo-favicon/
