We got same issue a few months ago. On mobile phone, when I click homepage it appears with responsive theme. But if I click any topic it appears with normal mobile theme. I disabled and re-enabled the mobile theme plugin. But after a while the same thing happens again. The mobile theme plugin doesn’t seem to work properly. You can see the example pictures below.
Homepage: https://ibb.co/k03K53R
Topic: https://ibb.co/kBdBD18
Site: https://www.dijitalhobi.com
How can I fix it?
Thank you
If you want to use a mobile theme on the homepage, please check if you don’t disable the mobile theme for that page https://i.imgur.com/bjTcq2R.png
It is enable now as it was before. I don’t think it’s about “enable/disable mobile theme”. Because this issue happens automatically. Sometimes mobile theme error occurs out of nowhere.
I think it’s related with the plugin. Sometimes it seems to lose its function.
Everything looks normal now. Probably the same thing will happen again after a while.
Usually, this problem is caused by the cache plugin that you are using it doesn’t recognize mobile theme plugins. We recommend using the WP Super Cache plugin https://forum.tagdiv.com/cache-plugin-install-and-configure/
