Hello i recently bought Newspaper X, I have problem my chrome loads the mobile version on normal posts,at random times without any reason and im from desktop, And also when mobile plug in is active my phone randomly changes from mobile version to normal version
Hello !
This happens due to cache. Please follow our guide and make sure that WP Super Cache has been installed properly: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Let us know the result.
I am facing the same issue. Mobile version randomly appears on desktop and vice versa. It resolves in few minutes but is a minor irritant and maybe a put off for site visitors. Problem is I can’t configure the cache as my website host is WordPress.com and they manage their own cache. Installing my own caching solution is not recommended there. Is there any other workaround?
Hello !
Unfortunately from our experience WordPress.com can be a tricky host. You will have to let them know that you are having this issue. Unfortunately without a proper caching solution we cannot find a way to fix this. Also cache is affecting you in more ways not only theme side.
