Mobile version problem! Please help
I set up the theme. Works on the desktop. It looks different on the mobile version
Look here : https://ibb.co/6bLqxhQ
Hello !
The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme. The mobile editor will not render shortcodes !
You are now able to create mobile viewport templates as you can see in our guide here: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/
! Atention ! If you are using mobile templates you will have to remove the mobile theme plugin and also at the moment AMP is not working with mobile templates.
Please note that at the moment the Support team is not 24/7 available. We answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2
