Hi everyone,
I’m tottaly newbie here.. please help
I have issue with page speed for the first place.. I have installed the newsmag, sinced i also installed lot of others plugins. i’ve been experiment with jetpack mobile theme activated. In the beginning i thought it would get a long together with the newsmag theme, after a while.. it ruin my mobile looks. right away, i’m just deactivated the jetpack ( just like they said ) and it still stuck with the current jetpack mobile theme. Anybody could give me advices, what is wrong and what should i do?
Thank you..
The theme has been developed to be fast but it may still need configurations on this matters so test your site using google’s page speed insights testing tool(or gtmetrix) and make sure you follow the guide instructions and methods then test your site again.
First of all deactivate all plugins except Visual Composer, clear all caches then test your site page-speed again. In terms of speed we have made a page speed guide and covered the most important aspects that google notifies you of (image optimization, js/css render blocking and more..) and based on which it classifies and grades your site’ regarding speed. You can find it here: https://forum.tagdiv.com/how-to-make-the-site-faster/
If you decide to use the speed booster keep in mind that is an optional plugin and it was designed to work only with tested plugins – http://screencast.com/t/FXXDNtqfz in case you use other plugins it will be automatically disabled, so please check System Status – http://screencast.com/t/XAYYQgfRvEC To make it work with other plugins you will have to alter the code and remove/comment this – http://screencast.com/t/RZLIOPUNdqh Also you may find some useful information here: https://forum.tagdiv.com/topic/website-memory-problem/
Regarding your the mobile theme module from Jetpack plugin that was not teed to work with the theme and if it’s enabled it loads a different theme on mobile devices. For more details about this check this topic: https://forum.tagdiv.com/topic/newsmag-broken-on-mobile/
