module after post
Hi, how I can add module after post? I thont need show related articles, I need to show concret category after post.. any idea?
Hello motherboard,
Unfortunately, I do not exactly understand what you mean, sorry! As you can see, the theme has an option for displaying the Related Articles as you can see here -> https://www.screencast.com/t/IJUw0fPCaz after each post. What exactly do you want to achieve? Please provide more details so I will be able to provide a more accurate response. For more information about Related Articles feature, please consult our guide here -> https://forum.tagdiv.com/related-articles-2/ So, if you want to display more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
Hi, I just ask if we can add custom module after each post.
Hello motherboard,
Yes, it is possible but please notice that is not a simple task. Yo should edit each post template used by you on your website and add there your desired code. It is not a simple task and if you do not have a solid knowledge in this regard, please consider hiring a freelancer/developer to help you!
