Multi-Purpose Modules not showing up on TD Composer
Installed Multi-Purpose on my site http://www.BeyondTheTent.com and would like to use it to build a custom shop page with Woo-Commerce. Have disabled all plugins individually, uninstalled and reinstalled MP and still no luck. Any help would be much appreciated. Thanks
You can build a page normally with the composer elements you want, then set it as shop page in the Woocommerce settings. The theme blocks can display products if needed or you could use woocommerce shortcodes instead. This is a related topic
– https://forum.tagdiv.com/topic/how-to-display-products/
The composer does not have dedicated Woocommerce elements at this moment, so the woocommerce shortcodes would probably be the best to use to display products and other Woocommerce elements.
Let us know if you have more questions or you need help with something.
Thanks Simon. But what about getting Multi-Purpose to work on my site? I would like to use it to build out with elements such as the hero and others besides just woocommerce items. I would also like it for more than just the shop page, such as landing pages.
You can use multi-purpose elements or the additional options that it will add. All you need to do is to install and activate it
– https://www.screencast.com/t/7gMKIeG2la.
The plugin was introduced in a previous version of the theme and extends the tagDiv composer and also adds more settings in the theme panel
– https://tagdiv.com/newspaper-8-5-update-what-s-new/
The elements it will add will be visible in the tagDiv composer once you activate the multi-purpose plugin
– https://www.screencast.com/t/mHmdfzPK
– https://forum.tagdiv.com/tagdiv-composer-tutorial/
You can use multi-purpose elements on any page, as well as woocommerce shortcodes
– https://www.screencast.com/t/jzdAxwL3awg
– https://www.screencast.com/t/pJqu5xbUPEDj
I understand everything you are saying. I use Newspaper on another site and multi-purpose works great. It is installed MP on my site I mentioned above but none of the shortcodes are showing up in the front end TD page builder. Theme is up to date, TD Composer installed and so is Multi Purpose. Like I said, I uninstalled and re-installed everything and even deactivated plugins one by one. Why would the shortcodes not be showing up in the “Add Element” area?
Check the theme system status, make sure there are enough resources available
This can affect the theme and theme plugins functionality. If needed ask your hosting provider to increase theme as mentioned in the guide. Then check if the multi-purpose elements are displayed. Also clear the browser cache, or test with a different browser.
Let us know the results.
