Must Read block on post page
Hi there,
I want to display “must read” block on my post page. The post should display from post category. I checked widgets but couldn’t found this block.
Any help will be greatly appreciated.
Noticed only my post did not have replies so thought to bump post 🙂
Sorry for delay! Our support program is Monday – Friday: 8:00 AM – 17:00 PM and we answer to the most oldest topics so if you add new replies we get later to your topic.
Do you refer to this block from the demo? – http://screencast.com/t/6NJoAqpL6 This is block 1 and you can add it to your sidebar from Widgets area, just the block title is “Must Read” – http://screencast.com/t/wkpSrEhx8 and you can set your sidebar from Template Settings – http://screencast.com/t/bG4deTp04UoE but please note that if you use a custom sidebar for your category page it will overwrite this setting and it will be displayed category sidebar on articles(from that specific category) – http://screencast.com/t/l7EhS59O
Hope this helps!
Hi Alin
Thanks for the reply. Two things:
1. How do I display related post in block1?
2. When I expand tag_div widget it freezes my browser. I do not have this issue with other theme. Do you know the reason?
1. Please check widget settings, for tagdiv blocks you have the same filter settings like using pagebuilder(Filter Tab) – https://forum.tagdiv.com/block-settings-tutorial/ – http://screencast.com/t/VlXg3EJZgMI7
2. Not sure why you have this issue, please check this without any plugins active, leave only Visual Composer active, clear cache and see if it works. Also you can check browser console for errors when you expand the widget. It may be a server error, also you have to check the error.log to see if you can find something related to this issue. Let me know how it goes!
