Okay, I had a problem with my home page disappearing a few weeks ago, and I ended up just recreating it from the preloaded templates.
It has now disappeared again. When I try to edit it with TagDiv, this is what it says: “Error at zones: 6(models) : 5(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)” If I try to edit it with the regulat WordPress editor, it says: “There has been a critical error on this website. Please check your site admin email inbox for instructions.”
There are no instructions in my site admin email.
I was hoping to launch this website tomorrow! I have been having SO MANY problems with this theme I am thinking of abandoning it.Can someone please help me? Is there a way to stop this critical error from happening? I have disabled all the plugins except those that came with the theme or that were recommended by it.
https://thecarolinasequestrian.com/TCE/
If I try to edit it with the regular WordPress editor, it says: “There has been a critical error on this website. Please check your site admin email inbox for instructions.”
My menu is all categories and all of those pages work perfectly.
Please help before I make it worse trying to fix it.
For that error, please check this article: https://kinsta.com/knowledgebase/there-has-been-a-critical-error-on-your-website/
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and let me know the results!
Check this guide also: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
This issue with the error from Composer has been already discussed here: https://forum.tagdiv.com/topic/errors-at-columns-elements-5/
Please make sure you did all the steps which I mentioned here: https://forum.tagdiv.com/topic/errors-at-columns-1models-0dom-the-model-does-not-match-the-content-curr/
