hi,
Warning: mysqli_real_connect(): (HY000/2002): No such file or directory in /home//public_html/wp-includes/wp-db.php on line 1538
Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home//public_html/wp-includes/wp-db.php on line 1569
Warning: mysql_connect(): No such file or directory in /home//public_html/wp-includes/wp-db.php on line 1569
Hello finanspara,
Try to make a new clean install from scratch via FTP way because this is the surest theme method in this case. Also, make sure that you are using the latest version of the theme with all the plugins updated. Also, check your PHP version from your server to be according to our documentation here -> https://forum.tagdiv.com/requirements-for-newspaper/
