need help deleting author block
Is there any way I can delete the block that shows the authors picture,website etc. Whenever I preview the post it always shows the author on the bottom, and I have tried everything to get rid of it.
Hi enzomusto77,
Yes, you can remove it, but first you need to check if you are using a standard post template or cloud.
For standard post template you can remove this author box using the options from theme panel -> https://i.imgur.com/IOHtOkB.png
For single post template from tagDiv Cloud Library, you need to use tagDiv Composer to edit the cloud template and use the right click on the element you want to remove -> https://i.imgur.com/8yHchGa.png -> https://i.imgur.com/MU8V1dZ.png
Hope this will help you!
It does not help. I am using the cloud I have no idea where to begin. You sent me a picture and I don’t even know how to get to that part.
Hello !
If you are using Cloud library template then you will have to use tagDiv Composer as you can see here: https://www.screencast.com/t/arShxjAchPQ click to edit your template
Go to the author block and you can click on the deletion icon or you can right click and select delete. After that hit save here: https://www.screencast.com/t/FTTYfWOc
How are you getting there? its not giving me the option to edit the template
Hello !
Then we recommend you to use a Cloud library template in order to be able to fully edit it using tagDiv Composer. Follow our guide here: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
I have created the new template. Can you send me step by step instructions on how to add it to a post? I just need help with this last step. Thanks!
Hello !
Please take a look here: https://www.screencast.com/t/9CP02ZmdLf2G All you have to do is simply drag and drop it wherever you want.
I hope this was helpful !
