Need help on WooComerce + Printful + Newspaper integration?
Hi guys.
I recently installed the Newspaper theme, and I am super happy with it.
However – recently ran into some problems that seem to be caused by the Newspaper plug-ins.
THing is: I am trying to sell merch via the “print-on-demand drop shipping” service Printful.com and using WooCommerce as the webshop platform on my WP-site.
I know that Printfull and WooCommerce should work fine together, but I am getting these 500 error messages every time I try to upload a product to my store. It seems that the 500 error is caused by the necessary TagDiv Plug-ins that is needed for the rest of my site to work fine.
This is the error message I get:
“500 Internal Server Error occurred! Please check your server logs for a detailed issue description.
CODE: G97990924”
Have any of you experienced similar issues? Do you know how to fix it or do you have any tips?
Thanks in advance for any help.
Kim
Hello !
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
