Hi there,
I have a problem with the mobile theme plug-in. The problem is that when i go to the browser and try to inspect my website and then choose the mobile screen it works fine but when i quit the inspection and try to return back to my website in the browser it still keep the mobile theme even though i am using the whole browser screen and i try the incognito mode and i still get the mobile theme in the page where i did the inspection the first time so the only why i get this problem solved is when i clean my website’s cache which is not practical.
Any help would be great!
This is a problem related to the cache plugin. When the tagDiv Mobile Theme is used the cache plugin should have the option for “mobile cache” support enable to can make a separate cache for mobile version and desktop, for example – https://i.imgur.com/Jcy670Z.png – https://forum.tagdiv.com/cache-plugin-install-and-configure/
