Need help setting articles on home page
Hey guys, on my newspaper theme I have the big grid and then latest articles below. How do i set it so every recent article will show in the big grid part, but they push the older articles from the big grid down below where latest articles go?
I am having trouble showing duplicate posts on the big grid AND the latest articles below…
All help is appreciated!
Do you have only the Big Grid block on your page and you use a page template with latest articles?
A solution is to use the offset feature, for example you have Big Grid set to filter posts from all categories – http://screencast.com/t/1rEcBxdbJf just set the offset option for Latest Articles to 5 so it will display the 6’th post – http://screencast.com/t/jDXSgE8jF
Also you can filter by different categories(or tags) on your blocks – http://screencast.com/t/FRgOuWrCGoR – https://forum.tagdiv.com/block-settings-tutorial/ or you can use unique article feature(it is from old docs but works the same) – https://forum.tagdiv.com/unique-articles-and-offset-newspaper/ Please not that the unique articles feature was not designed to work with block pagination.
