Need help with my page speed
Hi. First i want to say thanks for this greate theme and please sorry for my bad english…
I habe a problem with my site page speed, i have reed all the posts that i have find (this and your documentation) but i can’t to make my website faster…
URL of my site: http://vidzo.ru/
Can you please say me step to step how to make pagespeed higher?
here is the code frome wp console
registered scripts
common | /wp-admin/js/common.min.js
admin-bar | /wp-includes/js/admin-bar.min.js
dashboard | /wp-admin/js/dashboard.min.js
customize-loader | /wp-includes/js/customize-loader.min.js
plugin-install | /wp-admin/js/plugin-install.min.js
media-upload | /wp-admin/js/media-upload.min.js
thickbox | /wp-includes/js/thickbox/thickbox.js
utils | /wp-includes/js/utils.min.js
svg-painter | /wp-admin/js/svg-painter.js
wp-auth-check | /wp-includes/js/wp-auth-check.min.js
wp_social_popup_js | http://vidzo.ru/wp-content/plugins/wp-social-popup-and-get-traffic/assets/js/plugin.js
ilentheme-script-admin | http://vidzo.ru/wp-content/plugins/wp-social-popup-and-get-traffic/assets/ilenframework/core.js
media-editor | /wp-includes/js/media-editor.min.js
media-audiovideo | /wp-includes/js/media-audiovideo.min.js
mce-view | /wp-includes/js/mce-view.min.js
image-edit | /wp-admin/js/image-edit.min.js
wpseo-admin-global-script | http://vidzo.ru/wp-content/plugins/wordpress-seo/js/wp-seo-admin-global.min.js
td-wp-admin-general | http://vidzo.ru/wp-content/themes/Newspaper/wp-admin/js/general.js
td-wp-admin-panel-js | http://vidzo.ru/wp-content/themes/Newspaper/wp-admin/js/wp-admin-panel.js
registered styles
admin-bar | /wp-includes/css/admin-bar.min.css
thickbox | /wp-includes/js/thickbox/thickbox.css
colors | 1
ie | /wp-admin/css/ie.min.css
wp-auth-check | /wp-includes/css/wp-auth-check.min.css
wp_social_popup_css_admin | http://vidzo.ru/wp-content/plugins/wp-social-popup-and-get-traffic/assets/css/admin.css
ilentheme-styles-admin | http://vidzo.ru/wp-content/plugins/wp-social-popup-and-get-traffic/assets/ilenframework/core.css
media-views | /wp-includes/css/media-views.min.css
imgareaselect | /wp-includes/js/imgareaselect/imgareaselect.css
wp-color-picker | /wp-admin/css/color-picker.min.css
google-font-ubuntu | http://fonts.googleapis.com/css?family=Ubuntu:300,400,500,700,300italic,400italic,500italic,700italic&subset=latin,cyrillic-ext,greek-ext,greek,latin-ext,cyrillic
td-wp-admin-td-panel-2 | http://vidzo.ru/wp-content/themes/Newspaper/wp-admin/css/wp-admin.css
wpalchemy-metabox | http://vidzo.ru/wp-content/themes/Newspaper/wp-admin/content-metaboxes/meta.css
And this is code from my htaccess
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
Options +FollowSymLinks
RewriteEngine On
RewriteCond %{HTTP_HOST} ^www.vidzo.ru\.ru$
RewriteRule (.*) http://vidzo.ru/$1 [R=301,L]
RewriteCond %{THE_REQUEST} ^[A-Z]{3,9}\ /index\.php\ HTTP/
RewriteRule ^index\.php$ http://vidzo.ru [R=301,L]
RewriteRule ^page/([0-9]+)(/?)$ index.php?cstart=$1 [L]
I am using dedicated server / VPS
Thank you
Check your site with GTMetrix.com and then follow all the suggests, in particular gzip/deflate, expiration headers, image optimization, remove versioning, minify your style.css, don’t use child theme, use fast server/hosting, remove all themes and plugins you’re not using except the latest twenty-fifteen theme, optimize your wp-config.php file to include absolute paths to your domain name, optimize font loading, limit loading external elements (e.g., social counters slow down page vs simple share buttons), limit number of ad networks (I’ve seen some people with six ad networks each loading java, css, and tracking code…. it’s ‘bloat’), use a local image for gravatars, etc.
I cover a number of these issues in detail in the sticky pagespeed thread. Look for my posts, and probably easier to go backwards from the end of the topic, vs from the start a year ago! 🙂
Can you please show me how and where i should add or delete codes or plugins to get pagespeed higher in google pagesped https://developers.google.com/speed/pagespeed/insights/?url= … i have try all the ways that i can but i can’t make speed higher…
Sorry for my bad english and thank you for your answer!!!
Basically you need to read through all of my suggestions as noted in prior note above.
Did you test your site with GTMetrix?
SEE: your test – http://gtmetrix.com/reports/vidzo.ru/1g4dDqXF
Note the items marked “server”
AND:
Read through all my suggestions here: – start on last page and go backward.
https://forum.tagdiv.com/topic/pagespeed/
(some of my suggestions are also in the theme docs already or were added, so you may want to start here: https://forum.tagdiv.com/how-to-make-the-site-faster/ )
  • This reply was modified 11 years by simchris.
Can you please say me is it true what i am doing?
1. Enabling Gzip compression and Set the Leverage Browser Caching
my htaccess
# BEGIN WordPress
RewriteEngine On
RewriteBase /
</IfModule>
# END WordPress
RewriteEngine On
<IfModule mod_deflate.c>
<filesMatch "\.(js|css|html|php)$">
SetOutputFilter DEFLATE
</filesMatch>
</IfModule>
# BEGIN Expire headers
<ifModule mod_expires.c>
ExpiresActive On
ExpiresDefault "access plus 5 seconds"
ExpiresByType image/x-icon "access plus 604800 seconds"
ExpiresByType image/jpeg "access plus 604800 seconds"
ExpiresByType image/png "access plus 604800 seconds"
ExpiresByType image/gif "access plus 604800 seconds"
ExpiresByType application/x-shockwave-flash "access plus 604800 seconds"
ExpiresByType text/css "access plus 604800 seconds"
ExpiresByType text/javascript "access plus 604800 seconds"
ExpiresByType application/javascript "access plus 604800 seconds"
ExpiresByType application/x-javascript "access plus 604800 seconds"
#ExpiresByType text/html "access plus 600 seconds"
#ExpiresByType application/xhtml+xml "access plus 600 seconds"
</ifModule>
# END Expire headers
is it ok?
2. Remove render blocking css/js – using the TagDiv Speed Boosterplugin (Advanced Users)
this is my code that i get from functions.php but i have a problem with this and i can’t to do it right can you please say me codes for my saite and where i shall add them?
registered scripts
registered styles
colors | 1
If you test your site using page speed insights pr gtmetrix you can find all issues you have to fix and also steps you need to follow to get this done: https://developers.google.com/speed/pagespeed/insights/?url=http%3A%2F%2Fvidzo.ru%2F&tab=desktop
Use the guide for page speed, without any additional plugins will help you achieve this just do some research on this because as stated in the guide this is not recommended if you are not aware of what you are doing, in this case I also suggest you get someone to help you with this.
As Chris also stated here:
..you can go trough the page speed topic as you will find answers to many of your questions there.
You can also find more info and suggestions here:
* https://developers.google.com/speed/docs/insights/LeverageBrowserCaching
* https://developers.google.com/speed/docs/insights/EnableCompression
* https://developers.google.com/speed/docs/insights/BlockingJS
* https://developers.google.com/speed/docs/insights/Server
* https://developers.google.com/speed/docs/insights/OptimizeImages
Hope this helps!
Hi Lucian.
Please can you help me i am a noob in this and i really need your help…Please analyse my website and give me codes and please say where i shuld add them…I have read all the topics but i cant do anything.
Thanks i really need your help
registered scripts
wp-mediaelement | /wp-includes/js/mediaelement/wp-mediaelement.js
registered styles
wp-mediaelement | /wp-includes/js/mediaelement/wp-mediaelement.css
colors | 1
the list of registered css and js
Please don’t ignore me i am not well with codding and i need your help
Did you add the items to your htaccess file ? Doesn’t look like it.
You need to do EVERYTHING ELSE before messing with the speedbooster plugin customizations, which are optional and entirely up to you.
You need to take care of ALL the other issues EXCEPT for “render blocking CSS/javascript” first or the latter will do nothing for your site. That step is done LAST to get the last couple of points, not the 25-30 points you’re down right now due to all the other issues that ONLY YOU can manage.
Web server optimization is up to you, and is related to optimizing WORDPRESS, not the theme. Tech support here is for the THEME, and not to teach you how to manage your web server … folks here are helping on that as time permits, but you have to take the initiative to LEARN how to do that — WordPress has been around 10 years — lots of tutorials on the web. “How to optimize WordPress for best Pagespeed” … simple search in Google, for example.
And all the links in this thread — SHOW YOU a number of things you should do, but you need to do that.
Nobody ignoring you — you need to fix your own house, that is YOUR job to tackle.
You’ve read the docs … well, now you need to actually *do* some of the guidelines or they won’t work.
Fix your htaccess file; make sure you have compression running, and expiration headers; optimize your images; minimize external elements loading on your site; etc. — ONLY YOU can do that stuff. If it means nothing to you, then you likely will need to hire a developer to help you.
Don’t test with GTMetrix it is not really accurate to be honest. Use this tools.pingdom.com. For example I test my website and also big website names such as cnet.com etc for example for cnet in GTmetrix it shows sometimes 3 seconds sometimes 20 seconds sometimes 6 seconds it is not really efficient… Another example just tested pcmag.com it shows 10 seconds. Overall I don’t use GTMetrix because I think pingdom has more servers to test and consistent test speed and results you can try it yourself and see!
  • This reply was modified 11 years by kovachx.
GTmetrix.com is useful for newbies as it shows examples and also offers fixes such as optimized versions of problem images and minified elements for those unable to do that stuff themselves. I usually recommend it as opposed to Google’s own Pagespeed Insights, since Google doesn’t really explain very well how to fix anything. GTM also has a plugin you can use to chart your improvements (or they did anyway).
I will admit I have worked with their parent company for 15 years several times on client projects, hence my high level of trust.
Still – one needs to follow the advice provided by ANY of the docs, posts, or online tools, as starting point to optimize a site; it won’t fix itself 🙂
