Need help with PHP Fatal error caused by tdc
I have been getting errors like this in my error logs. Would you kindly advise how best to troubleshoot?
Kindly note that the timestamp coincides with server errors 520 and 524 timestamps reported by my users.
2022-04-07 14:56:43.745176 [NOTICE] [25529] [T0] [{{hiddenIP}}:{{hiddenPort}}:HTTP2-5#APVH_{{hiddendomain}}:443] [STDERR] PHP Fatal error: Cannot redeclare tdc_on_remove_core_updates() (previously declared in /home/{{hiddendomain}}/public_html/wp-content/plugins/td-composer/includes/tdc_main.php:359) in /home/{{hiddendomain}}/public_html/wp-content/plugins/td-composer/includes/tdc_main.php on line 358
  • This topic was modified 4 years by Redlemon.
I recommend you to change your php version as recommended in our guide here: https://forum.tagdiv.com/requirements-for-newspaper/
If the problem persists, then we can investigate further via email.
Hi Bettina,
Your guide recommends a PHP version equal to or greater than 7.3. Our site runs on version 7.4 which meets your suggestions.
Please proceed with proper instructions for further investigation.
If you sent an email, then we will take a look and reply to you as soon as possible.
