Please check the Screenshot
1- I want to lessen the Gap between Title and Post hero Image
2- Lessen the gaps from both Right and left sides in Post Text Only, not the Image but the Post Text Only as shown in image/screenshot
Hope Im not asking for too much…
If you are using tagDiv Composer to build the page, you can get a template from tagDiv Cloud library and edit it
https://www.screencast.com/t/kfd64e8pbOx
https://www.screencast.com/t/jkgvaFzo9v
Maybe I was not clear first time, you can get a post template from tagDiv Cloud Library and you can edit that template with tagDiv Composer and change it how you want.
Or if you do not want to change the post template, then you’ll need to add some custom css, in order to do that please provide a link to a post with this template, in this way I will be able to provide you the right custom css.
