Need help with some feature! Which plugins are compatible and which ones to use?
Firstly, I need to tell you guys, your support is awesome!
Ok, so we are progressing and need few features:
1) Live Blog – do we have this feature inbuilt in newspaper, if not which plugin to use that is compatible with Newspaper.
2) Infinite scroll – in articles/smart lists ( see example – https://tinyurl.com/ya7vdh94) If you see this smart list link it works like infinite article load with each slide generating new link/page view in one smooth format. Is the feature now available or any plugin which we can use for this with newspaper theme.
3) Best cache/optimisation plugin to use with Newspaper theme on shared server.
4) Is a comparision/spec sheet feature available in newspaper? (Please see example here – https://www.gsmarena.com/lenovo_z5_pro-9349.php or https://tinyurl.com/ydgkdcxh) if not, then which plugin can we use that is best compatible with Newspaper.
SP
Thank you very much for your appreciation. We try to add new features with each update, but we have to be careful what is added however, and also what will be the consequences.
1. Can’t say I know much about live blogging. I read some articles online to see what this presumes. The theme doesn’t have such an option at the moment, we haven’t made any tests with plugins that can offer the option unfortunately. As for plans to add this in the theme, I am not aware of them.
2. For implementing infinite scrolling in the post page there are plans. This is a much requested feature and a solution will be found to add this in the theme by default, as soon as possible.
3. For caching we tested the WP Super Cache (works properly with mobile theme plugin if used), but other caching plugins may work as well.
4. So something to compare items in a table like format or similar, that is not available in the theme or composer. I can’t make any plugin recommendations unfortunately, test the plugins you can find which can offer this functionality.
Sorry for any inconvenience.
Oh,
Ok for the 2nd point my recommendation is make it such so that each scroll to the new article also changes the top URL. so that each new article is counted as a new pageview.
Is there a way to turn on/off the mobile theme?
I believe that is how the infinite loading will work, with changing URLs.
The mobile theme plugin is optional, deactivating it will not cause problems. Use it only if you want to display a different and much simpler version of the website on mobile
https://forum.tagdiv.com/the-mobile-theme/
Super, hope we get infinite loading on smart lists too.
