I have a bad score on gmetrix on my site: sosialnytt.com
Minimize redirects
Minimize request size
Serve resources from a consistent URL
Leverage browser caching
Defer parsing of JavaScript
Enable Keep-Alive
Inline small JavaScript
I use speedbooster, and have removed the codesnippet that stops the plugin from working when I have other plugins activated than those on the “accepted list”.
Do you have any tips for changes I could easily implement to get better speed/score?
I have checked your site and from what I see your resources are not loaded in footer, so I guess Speed Booster is not active or it is not configured to move the resources to the bottom.
Also you did not applied please the other pagespeed suggestions – https://forum.tagdiv.com/how-to-make-the-site-faster/ and check the official documentation – https://developers.google.com/speed/docs/insights/rules
Unfortunately the time doesn’t allow us to provide custom or optimization services, sorry! If you don’t have the required knowledge I suggest to get someone to help you.
Hi and thanks for the reply Alin,
I will try to make changes according to https://forum.tagdiv.com/how-to-make-the-site-faster/
But you have any guess why speed booster doesnt work? In my system status it says:
v4.5 – Active
I have also removed this code, so that shouldnt be the problem: http://www.screencast.com/t/RZLIOPUNdqh
Disable speed booster plugin amd try this guide once-
https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
