Need Help with the Big Flex Grid 1
I need some help editing the Big Flex Grid on my website.
My current flex grid looks like this: https://prnt.sc/Zv3BbZI0-Qfv
I want to make it like this: https://prnt.sc/I72ISfQO_OIt
Can you please share the code? I really need it.
Thank you in advance.
For this you need to check the settings from the Big Grid Flexhttps://i.imgur.com/8hYtK5P.png – if you want you can use the right click to reset the flex grid and after that just set the grid layout and the gap.
But that site has Flex Grid set to the width of entire page. Check out techworm.net.
The thing I am doing is only reducing the distance between 2 grids
Hi anubhavroy197, the big grid flex 1 on https://www.techworm.net/ is set like this, a row is set under the menu and is set on full width – https://i.imgur.com/Qiu0q6Z.png then the big grid flex 1 was dragged in the row and set on 3 modules and with a gat of 2px – https://i.imgur.com/3SrWx9y.jpg.
Thank you so much, Calin. This did the trick. You guys are brilliant!
