I need some help for my website and more specific the mobile theme. When I open my website from a mobile device, there are just my latest posts showing, without any blocks or grids. When I pick any category from the menu, there is a block showing so categories are fine. The problem is only at my homepage. Any ideas how to fix this? The website is http://www.allraps.com
The mobile version is look like that because you have the mobile theme plugin that provide you a better speed then responsive version of theme, but in order to achieve that speed you’ll need to create a new content for pages because in the most of cases those were made with builders ( tagDiv Composer, WPBakery ) and you need to use only the mobile editor ( you need to set the content for pages in mobile editor and this content will be display on mobile theme)
-> https://www.screencast.com/t/ebUIzt4se
Also the grids can be set from theme panel -> https://i.imgur.com/UNgtmDU.png
Since Newspaper v9.7.4 you can show the responsive version on mobile theme -> http://prntscr.com/oh6r2s you can check more details about mobile theme in our documentation -> https://forum.tagdiv.com/the-mobile-theme/
Thank you for your help, everything is ok now I deactivated the mobile theme plugin.
