Need mega menu with categories name 3 column and 3 at posts right
Need mega menu with categories name 3 column and 3 posts right like shown in the screenshot below. If yes please explain the steps
https://paste.pics/OFBOC
For what you want to achieve you need to use a modal popup element with the trigger button and set there an icon -> https://forum.tagdiv.com/modal-popup/
You need to create a page where you can add the element list menu, set the menu, and after set the page id in the modal popup.
Hi, the trigger is ‘click’-button, any chance for a mouse-over-solution, so that we generate the feeling of the normal menu? I need also more than one column for my categories. Thanks.
Or a tip how to build this 🙂
https://paste.pics/OPAYK
Unfortunately, this can be used only with a click. You can create the page as you want, and assign it in the modal popup.
Maybe you can tell us how to build this?
https://ibb.co/c8r9LYR
This is a page menu https://forum.tagdiv.com/page-menu/ you can create a menu in the page, and after placing it to the menu.
