Need urgent help
Product page in woocommerce isn’t loading fully. Please attend to asap
Also how do I update the theme
See the theme docs ! Link right side of page >>>>
If your product page is not loading fully then you might have plugin compatibility issues.
Please try to disable all your plugins, clear cache and reset cdn files.
As for the update: https://forum.tagdiv.com/how-to-update-the-theme-2/
