Good day team,
I have found or created an issue which I cannot figure out, after troubleshooting and searching the forum still no strong solution.
Have reason to believe this issue is also related to this one here – > https://forum.tagdiv.com/topic/unwanted-border-and-alignment-of-tiles-in-front-page/
Yet to be resolved.
The problem is reproducible when using visual composer layout. I place Grid, Block or WordPress widgets.
At first glance, the problem looks to be something to do with row margin or padding. But after many attempts, cannot successfully get the Header to line up with Grid, Block, or have the layout appear properly.
This is the screenshot -> http://www.goproace.com/wp-content/uploads/2017/03/5.png
and here is the link to the site showing the issues – > http://www.goproace.com/gopro-news/
Thanks so much in advance
Hello Ace,
Please ensure that you are using the latest version of the theme and also, you should use only the plugins that come bundled with the theme core files. The theme update should have to be done via FTP way because this is the surest method in this case, according to our guide here -> https://forum.tagdiv.com/newsmag-install-via-ftp/ Also, if you are using the child theme, switch it to the main theme and check the results.
Marking this issue as [Resolved] after receiving recommendations from Catalin
This issue is also fixed – > https://forum.tagdiv.com/topic/unwanted-border-and-alignment-of-tiles-in-front-page/#post-162684
What I did to resolve the issue:
– Deactivate third party cache plugins
– Install and activate WP Super Cache as recommended on tagDiv forum
– Delete third party cache plugins
– Revert wordpress theme to NewsMag default; no longer using child theme
