hello, two areas on my website that do not work in the newsletter and the sharing links on social networks as well as measuring their followers. As I show in the image below:https://www.screencast.com/t/4u3Wjwk3vbf9
You can also check the error on the website: https://opedreirense.com.br/
Hello !
Please make sure that you set each element properly as you can see in our guides here: https://forum.tagdiv.com/tagdiv-social-counter-tutorial-2/ and https://forum.tagdiv.com/the-newsletter-plugin/
Hi, I have the same problem, I also tried to set “cocacola” (without “”) as instagram page, but it doesn’t work too.
site: http://www.energiaincomune.com
This reply was modified 6 years by
nessunohastonick.
Just make sure that you are using the last version of theme v10.3.6 and you have set the Instagram id -> https://forum.tagdiv.com/instagram-widget/ after that the Instagram should work.
Let me know the results!
Okay, I updated the ID correctly as taught, but the follower count is not being updated automatically
Hi Irisvaldo Morais,
The Instagram , but note that is very possible that the number of followers to be 0 because Instagram restricted the access to there api, but using Instagram feeds should work. Our developers are working for a new implementation of that part, also we need for this a new Instagram id to get the followers and we do not get yet the approve for it. In the meanwhile you can set the Instagram fixed count -> https://imgur.com/mtYf7Lp
I understand, one more question this is happening on all social networks and not just on instagram, is it related to the same problem with the instagram id?
Hi Irisvaldo Morais, the problem was only for Instagram, for YouTube you need to make sure that you have set the youtube api key in theme panel and the rest of theme should work without extra api.
In my case it is not working well, the link even leads to social networks, but it does not update followers automatically, can you check out http://www.opedreirense.com.br and tell me how to solve it?
Usually this is when you are using some cache plugins, then is take some times and is not always actualized so fast.
If you want, we can take a look to this, send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
