http://www.RoskinGemNewsReport.com
So I have two rotating Banner Ads in the post content working just fine. I added the short code from Advanced Ads and I have 10 Ads rotating in the Article Inline Ad position after the 2nd paragraph, and I have another 10 banner Ads rotating in the Article Bottom Ad position. But I cannot seem to get the Sidebar Ad to accept a short code, not for one ad or a group of rotating ads. I am stumped. When I try to save the new code, the swirling squares do not stop. I have let them swirl over nite and that didn’t help either. Help!
I believe that it is possible to have something that is blocking the theme panel to save the settings. Usually, this can be checked using the browser console. Most of the time it is a restriction code set in htaccess -> https://i.imgur.com/mXzkPMo.png or a security module like wordfence.
I hope this will help you!
Hi Calin,
Is this what I am looking for?
/wp-admin/admin-ajax.php?td_theme_name=Newsmag&v=5.2.2:1 Failed to load resource: the server responded with a status of 403 (Forbidden)
It is the only Failed note I have in the console.
DevTools failed to load source map: Could not load content for https://img1.wsimg.com/tcc/tccl.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://img1.wsimg.com/traffic-assets/js/tti.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
Hi, yes, that is the javascript code that is blocked. It can be blocked by some security host settings (for example it can be blocked by wordfence or -> https://i.imgur.com/dW0WPWN.png), or from a deny code set in the htaccess file -> https://i.imgur.com/MZjJaHG.png -> https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Okay … This is WAY over my skill level. Any assistance would be greatly appreciated.
Please contact us via email at contact@tagdiv.com and please provide wp-admin and cPanel access. We’ll check it as soon as possible! Please include the link to this topic to can identify you.
THank you!
